You can communicate and exchange data with devices outside the Embed environment in the following ways:
• Interface with a USB Controller Area Network (CAN) device to read and write CAN messages on the CAN bus
• Connect to any OPC server and log data or run a virtual plant in Embed for offline tuning
• Perform real-time data acquisition and signal generation using National Instruments and Measurement Computing I/O cards, PLCs, and DCSs
• Perform serial I/O with other computers
• Exchange data over the ethernet using UDP
