Standalone Product Unit Draw
In addition to the applications listed above, there are several standalone products that draw Altair Units. The following table is a summary of AUs drawn of those applications.
Product | AUs | License Feature | Description |
Embed | 21 | EmbedCodeGen | An extension of EMBED Simulation Edition for model-based firmware development supporting all microcontrollers, and with enhanced support for the following: Arduino®, ARM®-Linux® Raspberry Pi™, STMicroelectronics®, and Texas Instruments™. |
Embed Simulation Edition | 10 | EmbedSimulation | A block diagram and state chart visual environment for modeling, simulation, analysis, and control system development. In addition to its simulation capabilities, it also supports real time data monitoring and control using National Instruments and other boards as well as OPC, CAN, UDP, Serial, and MQTT. |
Embed Basic | 1 | EmbedBasic | Same as EMBED Professional with a 100 block limit. |
Embed Digital Power Designer | 10 | EmbedDigitalPower | Used for the design and development of digital power supplies and power conversion equipment. DPD is an Add-On for Embed Professional. |
ElectroFlo | 30 | ElectroFloGUI, ElectroFloSolver | A Thermal package to simulate challenging electronics cooling and other EDA design applications. |
ESAComp | 6 | ESAComp | Composite design software. Units are stacked. |
FluxMotor | 15 | FluxMotor | A flexible, open software tool dedicated to the pre-design of electric rotating machines. |
PollEx PCB Modeler | 10 | PollExBasic | PCB Modeler |
PollEx PCB Solver | 30 | PollExSolver | PCB Solvers for signal integrity, power integrity, thermal analysis. |
PollEx PCB DfX | 50 | PollExVerification | PCB Design for Manufacturing (DfM), Design for Assembly (DfA), Design for Electrical (DfE), Design for Electrical Plus (DfE+) |
PollEx PCB DfX Post-processing | 21 | PollExPostVerification | PCB Design for Manufacturing (DfM), Design for Assembly (DfA), Design for Electrical (DfE), Design for Electrical Plus (DfE+) – Result visualization |
PollEx PCB UPE | 30 | PollExUPE | PCB Unified Part Editor |
PollEx PCB | None | PollExEntity | |
SimSolid | 30 | SimSolid, SimSolidBasic |
A structural analysis software for fast design iteration. It eliminates geometry simplification and meshing, enabling the analysis of fully featured CAD assemblies without meshing. Levels at first instance, stacks at second plus. |
