Types of Bushing Models
The HyperWorks supports three types of bushing models for static stiffness and three types for damping effects.
The HyperWorks exports all stiffness models, constant damping models, and rubber or hydromount damping models to the .gbs file for each direction. At run time, you can select the specific model that you want to use.
