Export/Import for CFD Solvers
![](../../../images/icons/fileExport-24.png)
![](../../../images/icons/fileImport-24.png)
- The File type field should be automatically set to CFD.
- In the Solver type field, make a selection from the drop-down menu of which solver type to export.
Export for CFX
- CAS Mesh
- This utility saves Fluent CAS/MSH files. These files contain volume and surface components used to specify boundary conditions. CAS/MSH files are imported by CFX with the added advantage that names used for all boundary zones (to impose boundary conditions) are imported into CFX without change. This facilitates the task of specifying boundary conditions for large models.
Fluent CAS/MSH Files
- Read
- Reads Fluent .cas/.msh files in BINARY or ASCII format. Both 3D and 2D (plane/axisymmetric) models are supported.
- Write
- Writes Fluent .cas or .msh files containing all the elements currently displayed. Before you start this writing process, display only the components/collectors that you want to export, such as the final 3D fluid domains (and any solid domains if present) and the components containing boundary zones (surface) to specify boundary conditions. Surface components should be extracted from ^faces collectors generated from the volume elements. In the case of 2D (plane or axisymmetric) models, all nodes in the mesh should have the same Z coordinate and perimeter zones for boundary conditions should be defined with components extracted from ^edges collectors generated from the 2D components defining the flow domain.
- Write (batch mode)
- Execute the following command:
hmbatch.exe-tclfluent_batch.tcl
where fluent_batch.tcl has the following contents:
set ALTAIR_HOME [hm_info -appinfo ALTAIR_HOME]
set output_template"$ALTAIR_HOME/templates/feoutput/cfd/general"
*templatefileset "$output_template" *readfile "C:/home/pipe.hm" *set fileName "C:/home/pipe_out.cas" *evaltclscript "$ALTAIR_HOME/hm/scripts/cfd/cfd_comm_proc.tcl" 0 *evaltclscript "$ALTAIR_HOME/hm/scripts/cfd/cfd_proc.tbc" 0 *evaltclstring "CfdCommProc_Fluent_save_msh$fileName"0
This will read in pipe.hm and export the mesh as pipe_out.cas in Fluent format.
STAR CD Vertex-Cell Files
- Read
- Reads native STAR CD .vrt, .cel, and optionally .bnd files in BINARY or ASCII format.
- Write
- Writes STAR CD .vrt, .cel, and .bnd files and also a .setup file that can be executed in pro-Star as an input file; this setup file imports the mesh from the .vrt / .cel files and creates all the boundary condition zones with default settings. Before you start this writing process, display only the components / collectors that you want to export, such as the final 3D fluid domains (any solid domains if present) and the components containing boundary zones to specify boundary conditions. Currently only STAR CD V3 is supported for import/export.
CFD++ Files
- Read
- Reads native BINARY CFD++ files: cellsin.bin, nodesin.bin, exbcin.bin, mcfd.bc, and so on. Both 3D and 2D (plane/axisymmetric) models are supported.
- Write
- Writes displayed components as native BINARY CFD++ files: cellsin.bin, nodesin.bin, exbcin.bin, mcfd.bc, and so on. Before you start this writing process, display only the components/collectors that you want to export, such as the final 3D fluid domains (and any solid domains, if present) and the components containing boundary zones (surface) to specify boundary conditions. Surface components should be extracted from ^faces collectors generated from the volume elements. In the case of 2D (plane or axisymmetric) models, all nodes in the mesh should have the same Z coordinate and perimeter zones for boundary conditions should be defined with components extracted from ^edges collectors generated from the 2D components defining the flow domain.
CGNS Files
- Read
- Reads CGNS files. Both 3D and 2D (plane/axisymmetric) models are supported.
- Write
- Writes all the displayed components to a CGNS file. Typically you will display only the 3D components / collectors representing fluid domains (any solid domains if present) and the components containing boundary zones (surface) to specify boundary conditions. Surface components should be extracted from ^faces collectors generated from volume components.
hmbatch.exe-tclcgns_batch.tcl
where cgns_batch.tcl has the following contents:set ALTAIR_HOME [hm_info -appinfo ALTAIR_HOME] set output_template "$ALTAIR_HOME/templates/feoutput/cfd/general" *templatefileset "$output_template" *readfile "C:/home/pipe.hm" set fileName "C:/home/pipe_out.cgns" *evaltclscript "$ALTAIR_HOME/hm/scripts/cfd/cfd_comm_proc.tcl" 0 *evaltclscript "$ALTAIR_HOME/hm/scripts/cfd/cfd_proc.tbc" 0 *evaltclstring "CfdCommProc_cgns_write $fileName" 0
CGNS (Structured) Files
- Write
- Both 3D and 2D (plane/axisymmetric) models are supported. Writes all the displayed elements to a structured CGNS file. Typically you will display only the 3D components / collectors representing fluid domains (any solid domains if present) and the components containing boundary zones (surface) to specify boundary conditions. Surface components should be extracted from the ^faces collectors generated from volume components. The name of a surface component should contain the name of the volume component to which the shells are attached to and the type of boundary condition applied to this zone, for example, fluid_wall, fluid_inlet, or interface_fluid_solid.
SC/Tetra Files
- Read
- Reads native SC/tetra *.pre files (only 3D models are supported).
- Write
- Writes native SC/tetra *.pre files. Only face-based BCs are written for all the displayed components containing surface elements. Before you start this writing process, display only the components/collectors that you want to export, such as the final 3D fluid domains (any solid domains, if present) and the components containing boundary zones (surface) to specify boundary conditions. Surface components should be extracted from the ^faces collectors generated from volume components (only 3D models are supported).
Open Foam Files
- Read
- Reads native Open Foam mesh files, only 3D models are supported. For import, select the folder name containing the directory constant, which also contains the directory polymesh. In polymesh you have files such as faceZones or cellZones.
- Write
- Writes native Open Foam mesh files in the Open Foam specific directory structure. Only face-based BCs are written for all the displayed components containing surface elements. Before you start this writing process, display only the components/collectors that you want to export, such as the final 3D fluid domains (any solid domains, if present) and the components containing boundary zones (surface) to specify boundary conditions. Surface components should be extracted from the ^faces collectors generated from volume components. If the name of the component has "Interface" in it then it is considered as "Interface."
