HM-4615: Model Import, Airbags, Export Displayed, and Contacts with LS-DYNA
In this tutorial you will define the following: *AIRBAG_WANG_NEFSKE for the airbag mesh geometry; initial velocity of 3 mm/ms in the negative x-direction for the head with *INITIAL_VELOCITY_GENERATION; a contact between the airbag and head with *ICONTACT_AUTOMATIC_SURFACE_TO_SURFACE; *CONTACT_AIRBAG_SINGLE_SURFACE for the airbag; and a contact between the plate and the airbag with *CONTACT_NODES_TO_SURFACE.
![](../../../images/tutorials/hm/hm_4615_head_and_airbag_model.png)
LS-DYNA Overview
In this section, you will learn how to import a LS-DYNA model, export displayed, and create and review contacts.
Import a LS-DYNA Model
- Warning and Error Messages
- When importing a LS-DYNA model, Engineering Solutions warning and error messages will be written to a file named dynkey.msg or dynaseq.msg, depending on the FE input translator being used. This file is created in the same folder from which Engineering Solutions was started.
- Unsupported Cards
- On import, the LS-DYNA cards not supported by Engineering Solutions are written to the unsupp_cards panel. Access this panel by clicking from the menu bar. Unsupported cards will be exported with the remaining model.
- LSTC Dummy Files
- You can read LSTC Hybrid III dummy files into Engineering Solutions by first converting the tree file to FTSS/ARUP tree file format.
- Include Files
- Engineering Solutions supports *INCLUDE. When Include files are imported into Engineering Solutions, the IDs of non-existing entities are maintained and will not be used for new entities. Use the Include files import option to specify whether to merge, preserve, or skip Include files on import. Access this option by clicking from the menu bar.
Export Displayed
From the Export - Solver Deck tab, select the Export Displayed option to export only displayed nodes and elements. Only model data associated to the displayed nodes and elements are exported. This model data includes materials and their associated curves, properties, portions of contacts, and output requests.
Create and Review Contacts
Table 1 describes how all slave and master set types are created and specified in contacts.
Slave and Master Set Type | LS-DYNA card | Panel Used to Create Card | Equivalent type in Interfaces panel, add subpanel | ||
EQ. 0: set segment id | *SET_SEGMENT | set_segment (contactsurfs) or … | csurfs | ||
Interfaces, add subpanel | entity | ||||
EQ. 1: shell element | *SET_SHELL_Optio | Entity Sets or… | sets | ||
set id | n | Interfaces, add subpanel | subpanel entity | ||
EQ. 2: part set id | EQ. 2: part set id | Entity Sets or… | Interfaces, add subpanel | split | comps |
EQ. 3: part id | *PART | Collectors | comps | ||
* EQ. 4: node set id | *SET_NODE_Option | Entity Sets or… | sets | ||
* EQ. 5: include all | Interfaces, add subpanel | all | |||
* EQ. 6: part set id for exempted parts | *SET_PART_LIST | Interfaces, add subpanel and then card image subpanel | sets |
- Add Subpanel
- While the Interfaces panel, add subpanel has several master and slave entity types to choose from in order to specify the LS-DYNA master or slave set for a *CONTACT, only the valid master and slave types are selectable for the particular contact you are creating.
- Review Contacts
- Review contacts by clicking review in the Interfaces panel, add subpanel.
Load the LS-DYNA User Profile
In this step, you will load the LS-DYNA user profile in Engineering Solutions.
- Start Engineering Solutions Desktop.
- In the User Profile dialog, set the user profile to LsDyna.
Import the LS-DYNA Model
In this step, you will import the LS-DYNA model file into Engineering Solutions.
Define *AIRBAG_WANG_NEFSKE
In this step, you will define *AIRBAG_WANG_NEFSKE for the airbag mesh geometry.
Create a set of parts, *SET_PART_LIST, containing the AirbagFront and
AirbagRear components.
Define the airbag (*AIRBAG_WANG_NEFSKE).
Define an initial velocity of 3 mm/ms in the negative xdirection for the head
with *INITIAL_VELOCITY_GENERATION.
Define a Contact Between the Airbag and the Head
In this section, you will define a contact between the airbag and the head with *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE.
Define a Contact Between the Plate and the Airbag
In this step, you will define a contact between the plate and the airbag with *CONTACT_NODES_TO_SURFACE.
Review the Created Solver Entities
In this step, you will review the created solver entities using the Solver Browser.
Export the Model
In this step, you will export the model to an LS-DYNA 971 formatted input file.
Submit the Input File
In this step, you will submit the LS-DYNA input file to LS-DYNA 970.
- From the Start Menu, open the LS-DYNA Manager program.
- From the solvers menu, select Start LS-DYNA analysis.
- Load the airbag_complete.key file.
- Start the analysis by clicking OK.
View the Results
In this tutorial, you will view the results in HyperView.
