Edit Criteria and Parameter Files
Set the appropriate parameters/options to obtain the desired mesh by editing the criteria and parameter files.
Use the Criteria Editor and Parameters Editor to create and modify mesh criteria files as well as geometry cleanup parameter files.
Open the Criteria Editor and Parameters
Editor.
- In BatchMesher, Configurations tab, right-click on an entry in the Criteria File and Parameter File columns and select Edit File from the context menu.
- From the menu bar, select .
- In the Criteria Editor and Parameter Editor dialogs, edit criteria and parameter settings.
Save your changes.
- Click
(Save File) to saves the currently loaded file. If no file is loaded, a prompt will be given for a new name.
- Click
(Save File As) save the current settings to a new or different file name.
- Click
- Click Apply to save your changes and continue editing or click OK to save your changes and close the window.
