View new features for HyperMesh 2020.
Discover HyperMesh functionality with interactive tutorials.
Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
HyperMesh composites and tools.
HyperLaminate is a HyperMesh module that facilitates the creation, review and edition of composite laminates.
Overview of the HyperLaminate environment.
The HyperLaminate menu bar provides access to menus that allow you to manage files, edit materials, laminates, HLS loadcases and design variables, change views, and access online help.
The HyperLaminate toolbar contains tools that allow you to generate new materials, laminates, HLS loadcases or design variables, and to cut, copy, paste, and delete entries in text boxes.
The Laminate Browser provides a vertical tree view of the materials, laminates, and HLS loadcases in your model.
The HyperLaminate Solver (HLS) uses classical laminated plate theory to analyze composite laminates subject to various in-plane and thermal loading conditions.
The Define/Edit Pane, the central pane of the HyperLaminate window, allows you to edit the definition of the selected entity.
The Review/Results pane allows you to review the information pertaining to the selected entity as well as displaying HyperLaminate Solver results for laminates.
Methods to create and edit materials in HyperLaminate.
Methods to create and edit laminates in HyperLaminate.
Methods to create and edit design variables in HyperLaminate.
Import geometry into your current HyperMesh session, and set advanced import options.
All entities in a HyperMesh database are stored in collectors. Based on the assigned template, each collector may use a dictionary or card image to define the attributes assigned to the collector. The definitions contained in the dictionaries or card image are used to translate models to external analysis codes.
If geometry is not available from a CAD system, you can create or edit geometry in HyperMesh.
A temporary node list retains nodes that are not attached to an element, protecting them from automatic removal by the database management.
Overview of how to select surfaces in wireframe and shaded mode.
Each surface contains one or more faces. It is usually preferable to combine multiple faces into one surface entity before you use the meshing tools.
Nodes and elements can be associated to surfaces.
Prepare surface geometry for meshing.
The final step in the model building process is to apply constraints and forces and to create or assign coordinate systems.
Systems are referred to as coordinate systems and may be rectangular, cylindrical, or spherical.
Overview of tools used when setting up your model.
Control cards allow you to add input and output parameters to a model, including location and names of the input, output and scratch files; the type of run (analysis, check or restart); overall running of the analysis or optimization; and type, format and frequency of the output.
Boundary Conditions define limits as well as loads on geometry and mesh.
