In this tutorial you will learn how to set up edge to edge contacts, set up contacts manually, and create edge to
edge contacts between circular and rectangular parts of a model.
In this tutorial, you will: mesh all of the surfaces at once; define the dummy properties and assign them to the mesh;
define an orientation for the component; use the Ply Realization and distribution table option; laminate realize;
create and edit a distribution table; and use the Ply thickness visualization representation option.
Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
HM-4400: Explore the ANSYS Interface
In this tutorial you will learn about HyperMesh’s ANSYSFE input reader, template, macro menu, and user profile.
HM-4410: Set Up a Model in ANSYS
In this tutorial you will learn how to create and define elements, real constants, materials, properties, components, and loadsteps.
HM-4420: Define ANSYS Contacts for Models in HyperMesh
In this tutorial you will learn how to set up edge to edge contacts, set up contacts manually, and create edge to edge contacts between circular and rectangular parts of a model.
HM-4450: Introduction to HyperBeam
In this tutorial, you will learn how to couple degrees of freedom and to assign a standard beam section using the Section and HyperBeam panels.
HM-4460: Composite
In this tutorial, you will: mesh all of the surfaces at once; define the dummy properties and assign them to the mesh; define an orientation for the component; use the Ply Realization and distribution table option; laminate realize; create and edit a distribution table; and use the Ply thickness visualization representation option.
