Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
The middle section of the Connector Browser contains a tree view of all the connections contained in the model, and has its own set of tools similar to the
ones found in the Link Entity Browser.
This tool set, located at the bottom of the Connector Browser, provides tools for output of a Master Connectors File, opening specific connector-related HyperMesh panels, or utilize specialized visualization options.
A link is a reference to a separate entity. One or more links are added to a connector. The entities to which the
links refer are connected during realization.
Combine aligned single point connectors into line connectors or combine several aligned seam line connectors into
larger one(s) using the Combine option.
Existing connector links can be converted to one of the following link types: Part, Comp, or Prop. Connector link
conversion requests a clear 1:1 relation between a component and a property, otherwise the conversion is not unique
and will not be performed.
The find parts feature in the Connector Browsercontext menu finds the entities/part(s) connected by specific connector(s), and isolates them in the graphics area.
The Utility menu contains options that allow you to customize the standard interface to include function buttons, radio options, and
text that have HyperMesh-supplied and user-defined macros associated with them.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Comp, or Prop. Connector link conversion requests a clear 1:1 relation between a component
and a property, otherwise the conversion is not unique and will not be
performed.
Links can be converted in the Connector Entity Browser.
Right-click on the connector icon and select Convert
Links from the context menu to convert
all of the links of all the selected connectors at once.
For a single link conversion right-click on the exact link and select
Convert Link from the context menu. Figure 1.
