Edit an Existing Clearance Definition for a Contact Pair
If you created a clearance definition using the Entity Editor, Interfaces panel, or imported a clearance definition for a given master-slave pair, you can display and edit the clearance details in the Contact Manager.
  1. To read and display an existing clearance definition for a master-slave pair, select the Small sliding checkbox in the Parameter tab.
  2. In the Clearance tab, edit the clearance details.
  3. Click Apply.
