Load the ANSYS user profile.
From the Tools menu, select Ansys Surface Manager.
Click Auto.
The Auto Contact dialog opens.
In the Contact Type: field, select the type of contact pair to create.
Click the yellow components button to select your
components.
The components are automatically placed in the Component table in the
Auto Contact dialog. The proximity distance is the
maximum distance between two selected components. When you create the pair, any
surfaces that are farther away than the value entered here will not be created
as a contact pair. The default value is zero.
In the Maximum reverse angle field, enter a value.
If the angle between two normals of elements or element faces exceeds this
value, the element will not be added to the master or slave surface.
Click Find.
The status bar activates and the Auto
Contact browser opens.
Use the Auto Contact browser to make any necessary
adjustments to the interface and surfaces. When finished modifying, click
Create.
The interfaces and surfaces marked as accepted are created. The Contact
Manager window reopens with the new information listed.
