Conn Menu
The Conn menu contains options that let you manage connectors in the model.
Renumber
NodeID/Plink ID
Node ID
Renumber nodes for displayed plinks such that plinkId = plinkNodeId.
Plink ID
Renumber displayed plinks such that plinkId = plinkNodeId.
Connector Panel
Feabsorb/Quality/Realize
Enters the Connectors panel, and then fe absorb/quality/fe realize panel, depending on the selected macro.
Find att to P(X)LINKs
Ces
Finds connectors attached to the displayed link entity.
Com
Finds all components attached to the displayed link entity.
Mcom
Finds all master components attached to the displayed link entity.
Scom
Finds all slave components attached to the displayed link entity.
Find att to CE
PL
Finds Plinks attached to the displayed connectors.
Com
Finds all components attached to the displayed connectors.
Find att to Comps
Finds entities attached to the displayed components.
Find/Mask
Finds/Masks the entities depending upon the selected macros.
