Link Input Variables
Reduce the number of independent variables and/or of different models in multi-model studies in order to have synchronized design updates between models by linking input variables to each other.
Input variables can be linked within or across models.
The input variable of a model can also be linked to the output responses of other models. If the input of a model is a function of outputs of other models, you can add an input variable for the input of the dependent model and responses for the outputs of the independent models, and link the input variable to the output responses by entering the dependency in the expression field.
