Criteria for Formulating an Optimization Problem
In order to formulate a design problem as an optimization problem you must identify input variables, objective functions, and constraint functions.
When you put input variables, objectives and constraints together, you get the optimization formulation for a design problem as shown in Table 1.
Refer to Objectives and Constraints for more information.
Type | Formula(s) | Example |
Objectives | ||
Constraints |
Design Space |
- f(x) is the vector of system output responses that are used as objectives.
- g(x) and h(x) is the vector or system output responses that are used as inequality and equality constraints.
- x is the vector of input variables.
- Optimum Design
- The point or design that minimized (maximized) the objective function and at the same time satisfy all the constraints.
- Violated Constraint
- Constraint that is not satisfied.
- Active Constraint
- Constraint that is satisfied exactly; equality constraints are active for feasible designs.
- Inactive Constraint
- Constraint that satisfied but not on the bound.
- Feasible Design
- A point or a design that satisfies all the constraints.
- Infeasible Design
- A design that violates one or more constraints.
Figure 1. Design Space Definitions
