tblITableEditor GetColumnName
Returns the name of a column.
tblITableEditor_handle GetColumnName columnindex
HyperWorks Tcl Query
This command returns the name of the column for a given column index.
columnindex
Index of the column.
Get the column index (50) from the column name (AX) and save it in a variable:
set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set indexColumnAX [$activetableHandle GetColumnIndex AX]
