Use the Process Manager to rapidly develop and deploy process automation applications for standard product engineering practices within the HyperWorks environment using the Process Manager.
Automate is an advanced flow-based utility for authoring processes.
File formats and extensions associated with a process, and supported operating systems.
User and software prerequisites.
Terms and definitions associated with Automate.
Overview of the Automate tool user interface.
Learn how to run a math task, create a process with math tasks and load a task.
Learn how the Task Builder helps you to create new tasks, data types, and processes, and save them inside of catalogs that are easily accessible from the Task and Process browsers.
Use the Task Builder Wizard to create a reusable task.
Overview about the two main files required to create a task: the Task file (.tsk) and the Task Implementation file (.tcl).
After modifying a task in the default text editor you can reload it and its associated data type.
You can save processes you wish to reuse into a new or existing catalog.
The Example Process tool lets you set breakpoints in your process and step through the execution of individual tasks.
During an Automate session, you can save your work in progress, and at any given time reload the session and resume working from the exact point where you left off.
Use the Batch Mode function to create a process and share it as a package.
The Automate API's let you call the most frequently used functionality in the software.
ON THIS PAGE
ON THIS PAGE
