Prefix All Curves with an Iteration Identifier
- From the View menu, select Browsers > HyperWorks > Parameters to display the Parameters Browser.
Right-click within the white space of the browser and
select Expand All.
The browser is expanded to show the entire contents of the session.
- Right-click on a curve and select Select All from the context menu.
Activate the checkbox next to Name.
A new row is added to the lower portion of the parameter table.
- Click the ellipse button, , next to the default curve name to display the More Options dialog.
- In the Name field, enter Run ID:.
- Change Value type to Prefix.
- Change Default value to Run 1.
- Click OK.
- Click Save, , to save the script template.
- Click OK.
- From the Reports toolbar, click the Open Report Panel icon, , to display the Flexible Report Templates dialog.
- In the Run ID field, enter Run 2.
Click Apply.
The session is recreated and all curve names have Run 2 at the start of their name.
