Plane and Vector Selector
The Plane and Vector selector is used in many panels, the Entity Editor or dialogs to define a plane or a vector (direction) to perform a certain function.
For example, the Translate panel requires that you define the direction of translation, while the Reflect panel requires a plane for the creation of the mirror images of the entities selected.
Figure 1. Plane and Vector Selector
Figure 2. Selector in Position and Linear Solid Panels. Selector resembles the Plane and Vector selector, but is used to map entities from one location to another.
(Switch)
- Select the method for defining the plane or vector.
- x-axis, y-axis, and z-axis
- Define the first, second or third axis respectively of a coordinate system in your model. This coordinate system may be the global coordinate system, or a local system when one can be explicitly specified. Local systems may be rectangular, cylindrical or spherical.
- vector
- Specify a vector entity (created in the Vectors panel). This includes vectors defining coordinate systems, and loads as well.
- N1, N2, N3
- Define a vector (N1,N2), or plane (N1,N2,N3). When defining a plane, the resulting vector is normal to this plane following the right hand rule, and passes through either N1 or the base node (if one is specified).
- screen normal
- Define a vector that is normal to the screen. For planes, as the vector defines the plane normal, the plane is within the screen.
- screen parallel
- Define a vector that is within the screen. For planes, as the vector defines the plane normal, the plane is perpendicular to the screen.
- Node Buttons
- When a node button is active (outlined with a blue border), you can select a node in the modeling window to automatically define it's coordinates. You can also click a node button to manually enter a node's coordinates. Once a node is selected, the next node button will automatically become active.
(Reset)
- Clear your selection (vector, N1,N2,N3 and base).
