Create and View Section Cuts
Use the Section Cuts tool to cut planar or spherical sections through a model.
Create Section Cuts
  1. From the View Controls toolbar, click .
  2. From the Section Cuts dialog, click to create a new section cut.
  3. Click of the left side of the microdialog to select either a planar or spherical section cut.
  4. Resize a spherical section cut by clicking on the face of the sphere and dragging the slider of entering a entering a value in the text box.
  5. Change the display and position of the section cut using the other microdialog options.
    • Display only the section cut by clicking .
    • Reverse the part of the model that is hidden by clicking .
    • Trim elements along the plane/sphere to create a smooth section cut by clicking .
    • Translate or rotate the section cut using the Move tool by clicking . After positioning, right-click to exit the Move tool.
    • Align the section plane to the x, y, or z-axis by clicking .
      Note: Only available for planar section cuts.
    Figure 1. Planar Section Cut
    Figure 2. Spherical Section Cut
Tip: To go back and adjust a section cut, right-click on it in the Section Cuts dialog and select Edit from the context menu.
View Section Cuts
  2. In the Section Cuts dialog, enable the checkboxes of the section cuts you wish to view.
    Figure 3.
Delete Section Cuts
  2. In the Section Cuts dialog, do one of the following:
    • Right-click on a section cut and select Delete from the context menu.
    • Select a section cut then click .
