Delete Constraints
Remove constraints from the model.
Delete constraints in the following ways:
- Select a constraint in the Design Explorer Browser then right-click and select Delete from the context menu or press Delete on the keyboard.
Click the Constraints tool satellite icon
. In the Constraints dialog, select the constraint to delete then click
