PLOAD1 Create and Review
Create and review pressure loads on 1D elements that are fully or partially loaded.
From the menu bar, click .
This tool can also be used to edit or review the PLOAD1 cards imported from a solved Nastran or OptiStruct data file.
Inputs are 1D elements and the start/finish local parametric values and the pressure at those points (start and end pressures).
![](../../../images/partially_loaded_beam.png)
Figure 1. . A partially loaded 1D beam. The load is applied between 0.3 and 0.6 local u values.
![](../../../images/create_and_review2.png)
Figure 2. Review the Existing PLOAD 1
