Bar/Beam 1D to 2D/3D Element Mapping
Use 1D source element data (results and current model with .csv) to map to 2D/3D target elements.
- Create or open a model containing 2D/3D target elements.
Create and define a field entity:
- In the Model Browser, right-click and select Create > field from the menu.
- In the Entity Editor, set Source Type to results file, or current model with .csv results file-based results of temperature or displacements from 1D source elements.
- In the Model Browser, right-click on the field and select Realize from the menu.
In the Field Realization dialog, define the realizations
settings:
Figure 1.- Set Field Type to temperature or displacement.
- Set Interpolation to shapefunction.
- Select the appropriate Loadcases, DataTypes, and DataComponents.
- Click Apply.
In the Field Realization dialog, click the
Contour button to contour the results.
