Convert Script to FVX
The Convert Script to FVX tool allows an AcuFieldView script to be read-in and the corresponding AcuFieldView Extension language (FVX) version to be created, in one step.
When you select this option, you will be presented with a file selector so that a script (.scr) file may be selected. The converted output file will be saved to the same directory as the input file.
