Material Model Commands
The Material Model commands are described in this chapter.
All the individual models except the models related to surface tension and radiation are collected by the MATERIAL_MODEL command. Every element set of a problem must be assigned a material model (every layer for a shell element set) and the material model must contain all the individual models corresponding to the equations of the problem.
