Messaging Mapping
Messaging mapping allows you to overwrite MotionSolve standard messages in the log file, or to append additional comments to the standard MotionSolve message.
You can customize messages by defining a CustomMessage element in the XML mapping file as shown
in the figure below. Based on the definition of the custom message, the log file will contain
customized information. Only messages with an ID tag can be customized.
The general syntax for the CustomMessage element is:
<CustomMessage
ID = "integer"
TYPE = { "INFO" | "WARNING" | "ERROR" }
ACTION = { "APPEND" | "OVERWRITE" | "DISABLE" }
TITLE = { "ON" | "OFF" }
WARN_COUNT = "integer"
Attributes | Description |
ID | Specifies a unique ID for the message. This must match with the message ID written by MotionSolve. |
TYPE | Specifies the type of the message (WARNING, ERROR, or INFO). The default is set to INFO. |
ACTION | Message action (APPEND, OVERWRITE, or
DISABLE). The default is set to APPEND. APPEND appends the custom message after the standard message. OVERWRITE uses the custom message instead of the standard message. DISABLE disables the message (both standard and custom message). |
TITLE | Specifies whether to enable or disable the title of the message. The default is ON. |
WARN_COUNT | Specifies how many times a specific warning is to be printed. The default values is -1, which represents infinity. This is applicable only to messages of the type WARNING. |
Creating a Custom Messaging API
Edit the <Messaging/> element in the MotionSolve XML input file as shown below:
