Build External Libraries
- External Optimization Responses (DRESP3 Bulk Data
Entry)
For responses which are not directly available via DRESP1 or DRESP2 entries, you can create your own responses in Fortran/C and build corresponding shared libraries for OptiStruct to use during the solution. Refer to External Responses for additional information.
- User-defined Materials (MATUSR Bulk Data Entry)
For materials which are not directly available via MAT# entries, and/or for additional flexibility in the material definition, you can create your own materials using Fortran/C and build corresponding shared libraries for OptiStruct to use during the solution. Refer to User-Defined Material for additional information.
The following sections illustrate the process of building external libraries using Fortran/C.
Windows Systems with Microsoft Visual Studio
Creating dynamic libraries in Windows with Microsoft Visual Studio can be done as follows. First create a new Project and in the New Project window, choose one of the following paths:
For Libraries built with Intel Visual Fortran compiler:
New Project > Intel Visual Fortran (Template) > Library > Dynamic Link Library
For Libraries built with C compiler:
- For Fortran libraries, you need to change the argument passing conventions in the project settings. Under the Fortran tab, select the category "External Procedures" and then change the "Argument Passing Conventions" to "C, By Reference".
- On Windows systems,
%PATH%
must be set correctly to ensure that the right compiler DLLs are picked up at runtime.
Linux Systems
- Create object files using either Fortran or C,
as:
- For Fortran:
FC [options] -c myfile.F -o myfile.o
- For C:
CC [options] -c myfile.c -o myfile.o
- For Fortran:
- Create Shared Libraries, as:
LD -shared [options] myfile.o -o mylib.so
FC
- The Fortran compiler (for instance
f77
) CC
- The C compiler (for instance
cc
orgcc
) LD
- The linker (for instance
ld
) installed on your computer
Refer to your system's manuals for more information.
The compiler and linker options provide information about the platform you are
building the library for. OptiStruct is a 64-bit
application and therefore, only works with 64-bit shared libraries or DLLs (the
corresponding options to build 64-bit shared libraries should be used). The linker
option “-shared
” specifies that you are building a shared library
(when using either Intel or GNU compilers). Other options, such as code optimization
parameters, are left to your discretion and should not usually affect the
compatibility with OptiStruct.
The following table defines options for each of OptiStruct's release platforms, which have been verified to work correctly on various systems. Keep in mind that these options might change depending on the compilers and linker installed on your computer. Refer to your operating system manual for further information. In most cases, GNU compilers can be used in place of Intel compilers. Use the appropriate compiler and linker options to create a shared library with the compiler of your choice.
You can generally use Native C compilers on both Linux and Windows, or Intel C compilers can be used to create shared libraries in C. If using Fortran, then Intel Fortran Compilers can be used to create shared libraries in Fortran. The Compiler version numbers should typically be chosen within the minor releases of the corresponding compiler versions used to build OptiStruct.
To determine this, you can run the OptiStruct script or
OptiStruct HWSolver Run manager GUI with the
-buildinfo
run option (the Use Solver
Control check box should be unchecked on the GUI) to obtain
information about the compilers used to build OptiStruct
executables and use similar compiler versions to build the shared libraries. This
information is under the header “Build Information” in the screen output after the
-buildinfo
run option is used.
Platform | Fortran Compiler Options | C Compiler Options | Linker Options |
Win64 | /iface:default
/libs:dll /threads |
/MT |
/LD |
Linux64 | -fPIC |
-fPIC |
-shared |
nm mylib.so
on Linux systems and
dumpbin/exports mylib.dll
on Windows systems with Microsoft
Visual Studio. This command will display the list of symbols found in the library,
among which you should recognize the function(s) which you have written.
