Previous (OS3.5) Input Format
OptiStruct will continue to support the old input format from version 3.5. The new optimization capabilities will not be available
if the old format is used for the set up of the optimization problem, that is, if matfrac, mini, maxi, ubcon or
lbcon are present. This section is intended to be used for the purpose of debugging or re-running older decks.
