The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
This section presents optimized topology examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used as a design concept tool.
This section presents size (parameter) optimization examples solved using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used in size optimization.
This section presents shape optimization example problems, solved using OptiStruct. Each example uses a problem description, execution procedures and results to demonstrate how OptiStruct is used in shape optimization.
The examples in this section demonstrate how topography optimization generates both bead reinforcements in stamped
plate structures and rib reinforcements for solid structures.
The examples in this section demonstrate how the Equivalent Static Load Method (ESLM) can be used for the optimization
of flexible bodies in multibody systems.
Demonstrates the response of water filled elevated tank structure.
Response spectrum analysis is carried out to estimate the maximum response of a
structure for a transient event. On a modal space when a response spectrum is
specified as dynamic loading, estimate the maximum displacement and stresses as a
response of the spectrum.
Figure 1. FE Model
Model Description
The finite element model, as shown in Figure 1 is constrained at the bottom of the
structure with all DOF’s fixed, modal damping with respect to natural frequency and
frequency dependent dynamic loads are applied on the structure.
FE Model
Element Types
CTRIA3
CBEAM
The linear material properties are:
Linear Material 1: STEEL
Young's Modulus (E)
2.1e5 MPa
Damping coefficient
0.02
Density (Rho)
7.9e-9 t/mm3
Linear Material 2: STEEL_SANDWICH
Young's Modulus (E)
3e4 MPa
Damping coefficient
0.02
Density (Rho)
9e-10 t/mm3
Results
The maximum response of the structure is analyzed for the transient loadings.
Figure 2. Maximum Displacement of the Structure
Figure 3. Maximum von Mises Stress in the Structure
