When computing eigen modes using Radioss (/EIG), for example to create an input file for a flexible body, CPU time and memory requirements can be greatly reduced
if a set of approximated modes is already available.
.h3d Output File
The .h3d file is a compressed binary file, containing both model and result data. It can be used to post-process results in HyperView.
Animation Output File (A-File)
The RunnameAnnn file is a binary file, containing both model and result data. It can be used to post-process results in HyperView.
ASCII Output File (STA-File) ASCII Output files are formatted output files from Radioss Starter and Radioss Engine.
ASCII Output File (STY-File) ASCII Output files are formatted output files from Radioss Starter and Radioss Engine.
Control File (C-File)
The optional control file is used to get information about a currently running analysis.
External Modes File
When computing eigen modes using Radioss (/EIG), for example to create an input file for a flexible body, CPU time and memory requirements can be greatly reduced if a set of approximated modes is already available.
