View new features for HyperWorks 2020.1.
Quick introduction to Altair HyperWorks and its suite of products.
Administrative tools to customize your HyperWorks installation.
The Altair License Utility is a tool allowing you to determine a host ID, check license usage, borrow licenses, and set up hosted HyperWorks Units.
AbaqusODB UpGrade is a HyperView tool, which upgrades ODB files created in Abaqus 6.2 (or earlier) to Abaqus 2020.
HvTrans is a result translator for HyperView that translates solver result files to H3D files.
The Altair GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HyperWorks commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
The Model Identification Tool, known as HyperWorks, is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The HyperWorks operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using the HgTrans GUI or via the HgTrans batch mode.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble HyperWorks automations with minimal effort and maximum portability.
The H3D Validation Tools available in HyperWorks are H3D Info and H3D Validate.
HyperWorks Verification and Validation Harness (HVVH) is a tool that can be used to verify and validate HyperWorks products. End users can use this tool to quickly evaluate the software quality, performance, reliability, scalability, and robustness, and to gain more confidence in HyperWorks products.
HVVH can be run in batch mode with a simple command line syntax using command line argument(s).
Use the Design tab for a solver check run. Inspire (OptiStruct) is supported.
Use the CAD and FE Model tabs to verify and validate CAD modeling and meshing.
Use the Solution tab for a solver check run and to submit a job (LS-DYNA, Radioss Block, and OptiStruct are supported).
The solver output results are used for further design verification and validation. The accuracy of the results as processed, interpreted, and visualized by a post-processor is key. HyperView is used to post-process most of the solver(s) results. Use the Result tab to ensure that HyperView does not deprecate any result information after post-processing.
Use the HyperForm tab to compare FE model data, solutions, and results across HyperForm versions.
Use the HyperXtrude/HyperMold tab to compare FE model data, solutions, and results across HyperXtrude versions.
Validation tests are used to execute user-defined verification script(s) in two different HyperWorks versions and compare the output files.
Uninstall HyperWorks is a tool to launch the HyperWorks uninstallation program. This program contains two options that allow you to either remove the originally installed files, or remove all the files that resides in the installation directory.
