MATX60
Bulk Data Entry Defines additional material properties for piece-wise nonlinear elastic-plastic material for geometric nonlinear analysis.
MATX60 MID EPSPF EPST1 EPST2 FSMOOTH C F EPSF
  TPID PSCA
Strain rate dependent material, at least 4 times, at most 10 times:
  TID1 FSCA1 EPSR1
  TID2 FSCA2 EPSR2
  etc etc etc
MAT1 102 900   0.33 1E1
MATX60 102
  101 1.0 4.2E-7
  102 1.0 4.2e6
MID Material ID of the associated MAT1. 1
No default (Integer > 0)
EPSPF Failure plastic strain.
Default = 1030 (Real > 0)
EPST1 Maximum tensile failure strain. 5
EPST2 Maximum tensile failure damage. 6
Default = 2.0*1030 (Real > 0)
FSMOOTH Strain rate smoothing flag.
OFF (Default)
ON
C Hardening coefficient.
0.0 (Default)
The hardening is a full isotropic model.
1.0
Hardening uses the kinematic Prager-Ziegler model.
Between 0.0 and 1.0
Hardening is interpolated between the two models.
(1.0 ≥ Real ≥ 0)
F Cutoff frequency for strain rate filtering. Only for shell and solid elements.
Default = 1030 (Real ≥ 0)
EPSF Tensile strain for element deletion.
Default = 3.0*1030 (Real > 0)
TPID Identification number of a TABLES1 that defines pressure dependent yield stress function.
PSCA Scale factor for stress in pressure dependent function.
Default = 1.0 (Real)
TIDi Identification number of a TABLES1 that defines the yield stress vs. plastic strain rate function corresponding to EPSRi. Separate functions must be defined for different strain rates.
FSCAi Scale factor for TIDi.
EPSRi Strain rate. Strain rate values must be given strictly in ascending order.
(Real)
  1. The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATX60 material extension can be associated with a particular MAT1.
  2. MATX60 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
  3. The first point of yield stress functions (plastic strain vs. stress) should have a plastic strain value of zero. If the last point of the first (static) function equals 0 in stress, the default value of EPSMAX is set to the value of the corresponding plastic strain.
  4. When the plastic strain reaches EPSMAX, the element is deleted.
  5. If the first principal strain ε 1 reaches ε t1 (EPST1), the stress σ is reduced by:
    (1)
    σ=σ(εt2ε1εt2εt1)
    with ε t2 = EPST2.
  6. If the first principal strain ε 1 reaches ε t2 (EPST2), the stress is reduced to 0 (but the element is not deleted).
  7. If the first principal strain ε 1 reaches ε f (EPSF), the element is deleted.
  8. Strain rate filtering is used to smooth strain rates. The input F is available only for shell and solid elements.
  9. Hardening is defined by ICH.
    Figure 1. Isotropic Hardening
    Figure 2. Prager-Ziegler Kinematic Hardening
  10. The kinematic hardening model is not available with global formulation (NIP = 0 on PSHELX), that is hardening is fully isotropic.
  11. In case of kinematic hardening and strain rate dependency, the yield stress depends on the strain rate.
  12. TPID is used to distinguish the behavior in tension and compression for certain materials (that is pressure dependent yield). This is available for solid elements only. The effective yield stress is then obtained by multiplying the nominal yield stress by the yield factor PSCA corresponding to the actual pressure.
  13. If ε˙nε˙ε˙n+1 ( ε˙n =EPSRn), yield stress is a cubic interpolation between functions fn-1, fn, fn+1 and fn+2.
    If ε˙ε˙1 , yield stress is interpolated between functions f1, f2, and f3.
    If ε˙Nfunc-1ε˙ε˙Nfunc , where Nfunc is the function number for strain rate, yield is extrapolated between functions fNfunc-3, fNfunc-2, fNfunc-1 and fNfunc.
    If ε˙>ε˙Nfunc , yield is extrapolated between functions fNfunc-2, fNfunc-1, and fNfunc.
  14. Strain rate values must be given strictly in ascending order. Separate functions must be defined for different strain rates.
  15. This card is represented as an extension to a MAT1 material in HyperMesh.
