MATX62
Bulk Data Entry Defines additional material properties for Hyper-visco-elastic material for geometric nonlinear analysis. This material is used to model rubber, polymers, and elastomers. This material is compatible with solid and shell elements.
MATX62 | MID | MUMAX | |||||||
LAW | MU1 | ALFA1 | MU2 | ALFA2 | MU3 | ALFA3 | |||
MU4 | ALFA4 | MU5 | ALFA5 | etc |
MAXWELL | GAM1 | T1 | GAM2 | T2 | GAM3 | T3 | |||
GAM4 | T4 | GAM5 | T5 | etc |
MAT1 | 102 | 10.0 | 0.495 | 6.0E-10 | |||||
MATX62 | 102 | ||||||||
LAW | 0.10 | 2.0 | -0.010 | -2.0 |
MID | Material ID of the associated
MAT1. 1 No default (Integer > 0) |
MUMAX | Maximum viscosity. Default = 1030 (Real) |
LAW | Indicates that material parameters MUi and ALFAi follow. | |
MUi | Parameter
μ
i. (Real) |
ALFAi | Parameter αi. (Real) |
MAXWELL | Indicates that MAXWELL model parameter pairs GAMi and Ti follow. | |
GAMi | Stiffness ratio
γi
. (Real) |
Ti | Time relaxation
τi
. (Real) |
- The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
- MATX62 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- NU is defined on the corresponding MAT1.
- If no pair GAM1, T1 is given the law is hyper-elastic.
- The
strain energy density W is computed using the following equation:
(1) W(λ1,λ2λ3)=N∑i=12μα2i(λαi1+λαi2+λαi3−3+1β(J−αiβ−1))with λi being the ith principal stretch, J = λ 1 * λ 2 * λ 3 being the relative volume and β=v(1−2v) . O < NU < 0.5
The ground shear modulus is:(2) G=N∑1μi - This card is represented as a material in HyperMesh.
