XSHLPRM
Bulk Data Entry Defines default shell element parameters for geometric nonlinear analysis.
XSHLPRM | I | I | I | I | I | NIP | I |
XSHLPRM | 24 | 2 | NEWT | 5 |
I | 4-node shell element
formulation flag.
(Integer) |
I | 3-node shell element
formulation flag.
(Integer) |
I | Shell small strain
formulation flag.
(Integer) |
I | Shell resultant stresses
calculation flag.
I | Shell plane stress
plasticity flag (MATX2, MATX27, and MATX36 only).
NIP | Number of integration
points through the thickness. Default = 5 (Integer 0 ≤ N ≤ 10) |
I | Drilling degree of freedom
stiffness flag.
(Integer) |
- XSHLPRM defines default settings for shell properties that can be overwritten by PSHELLX.
- XSHLPRM is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS=EXPDYN. It is ignored for all other subcases.
- Q4: Original 4 node OptiStruct shell with hourglass perturbation stabilization.
- QEPH: Formulation with physical hourglass stabilization for general use.
- QBAT: Modified BATOZ Q4 24 shell with 4 Gauss integration points and reduced integration for in-plane shear. No hourglass control is needed for this shell.
- DKT18: BATOZ DKT18 thin shell with 3 Hammer integration points.
- If the small strain option (I) is set to 1 or 3, the strain and stress are engineering strain and stress; otherwise they are true strain and stress.
- For MAT1, membrane only behavior happens if NIP=1. Otherwise, NIP is ignored and global integration (NIP=0) is used.
- For MATX2, the default value for I and global integration (NIP=0) is I=RAD.
- For MATX36, the default value for I and global integration (NIP=0) is I=NEWT.
- This card is represented as a control card in HyperMesh.
