XSTEP
Bulk Data Entry Defines explicit analysis control.
XSTEP | SID | TA0 | DTA | DTTH | NPRINT | RFILE | NITER | NPAMS | |
DTSCA | DTMIN | TSTYP | TACT | ||||||
TYPE1 | TSC1 | DT1 | DTM1 | ESID1 | AMST1 | ||||
TYPE2 | TSC2 | DT2 | DTM2 | ESID2 | AMST2 | ||||
etc. |
XSTEP | 2 | ||||||||
0.9 | DETAIL | ||||||||
GRID | CST | 0.9 | 0.1e-6 |
SID | Set identification number. (Integer > 0) |
TA0 | Start time for writing animation files. Default = 0.0 (Real > 0) |
DTA | Output time step for animation files. If zero, no output. 3 Default = 0.01*TTERMS(Real > 0) |
DTTH | Output time step for time history files. If zero, no output.
3 Default = 0.001*TTERMS(Real > 0) |
NPRINT | Print every NPRINT iteration. If negative, to
.out and standard output; if positive, only
to .out file. Default = -1000 (Integer) |
RFILE | Cycle frequency to write restart file for nonlinear iteration.
Default = 5000 (Integer > 0) |
NITER | Maximum number of iterations in conjugate gradient. Only valid when TSTYP=GRID and TACT=AMS. Default = 1000 (Integer > 0) |
NPAMS | Frequency (number of cycles) for writing additional output about
the number of iterations before convergence in the conjugate
gradient. Default = blank (Integer > 0) |
DTSCA | Default scale factor on explicit time step for all elements.
Default = 0.9 (Real > 0) |
DTMIN | Default minimum explicit time step. Default = 0.0 (Real > 0) |
TSTYP | Time step control type. 2
(Character) |
TACT | Action if minimum time step is reached (For
TSTYP=GRID,
ELEM, CONTACT. 3
TYPEi | Entity type selection. 4
No default (Character) |
TSCi | Time step control method. 4
Default = according to table (blank or Character) |
DTi | Time step scale factor for entity type. 4 Default = 0.9 (Real > 0.0) |
DTMi | Minimum time step for entity type. Default = 0.0 (Real > 0.0) |
ESIDi | GRID SET identification number (For
TYPEi=GRID, but
TSCi ≠ AMS). No default (blank, Integer ≥ 0) |
AMSTi | Tolerance for advanced mass scaling convergence (Only for
TYPEi=AMS). Default = 10-4 (Real > 0.0) |
- The XSTEP Bulk Data Entry is selected by the Subcase Information command XSTEP = option. It is only used in explicit analysis (ANALYSIS = EXPDYN); it is ignored in other analyses.
- Any number of continuation lines can be used.
- Time step control for explicit analysis.
- GRID
- Elements
- Default
- Do Nothing
- Options
- AMS, CST, STOP
- ELEM: Shells
- Default
- DEL
- Options
- CST, STOP
- ELEM: Solids
- Default
- STOP
- Options
- CST, DEL
- TSTYP=GRID
- The nodal time step is used. With this option, the computation of each cycle is slightly more expensive, but the time step can be higher, mainly for non-optimized meshes and therefore the overall runtime shorter.
- TSTYP=GRID
- TACT=CST, the mass of the grid that reaches DTMIN1 is increased. You should check the evolution of the mass of the model.
- TSTYP=ELEM
- TACT=CST, the element formulation switches to small strain for each element that reaches the DTMIN1.
- Overview of default settings
and options for TYPEi:
Do Nothing STOP DEL CST AMS SET SHELL N/A Optional Default Optional N/A N/A SOLID N/A Default Optional Optional N/A N/A CONTACT Default Optional Optional Optional Optional N/A GRID Default Optional N/A Optional Optional Optional - TYPEi=GRID
- The nodal time step is used. With this option, the computation of each cycle is slightly more expensive, but the time step can be higher, mainly for non-optimized meshes and; therefore, the overall runtime shorter.
- TYPEi=GRID and TSCi=CST
- DTi=0.67 is recommended.
- TYPEi=CONTACT and TSCi=DEL
- The impacted node which fixes the time step is removed from the interface.
- TYPEi=SOLID and TSCi=CST
- Only active for solid elements with the flag ISMSTR=2 set on PSOLIDX. This option is not available for 8 integration points.
- For more information about nonlinear analysis, refer to Explicit Dynamic Analysis (Radioss Integration) in the User Guide.
- TSTYP=NODA and TACT=AMS can activate elementary time step for Advanced Mass Scaling, as well as TYPEi=NODA and TSCi=AMS.
- NITER and NPAMS are only valid for Advanced Mass Scaling (AMS). If more NITER iterations have been performed before convergence of the conjugate gradient, the computation stops and error out. If NPAMS is specified, at each NPAMS cycle an additional output is provided including: the number of iterations before convergence of the conjugate gradient at this cycle, the final residual norm and the force vector norm.
- This card is represented as a loadcollector in HyperMesh.
