Create Collectors
All entities in a HyperMesh database are stored in collectors. Based on the assigned template, each collector may use a dictionary or card image to define the attributes assigned to the collector. The definitions contained in the dictionaries or card image are used to translate models to external analysis codes.
Change the Current Collector
By default, when you create a new collector it automatically becomes the current collector.
New components, loads, beam sections, multibodies, and so on will be created and organized within the respective current collector.
The current collector status is indicated in bold.
