Add a Verification Approach
Add approach to the study.
  1. In the Explorer, right-click and select Add from the context menu.
  2. In the Add dialog perform the following steps:
    1. In the Label field, enter a name for the Verification.
    2. For Definition from, select whether to clone the Definition defined in the study Setup or an existing approach.
      By default, the Definition defined in the study Setup is selected.
    3. Under Select Type, select Verification.
    4. Click OK.
A new Verification is added to the Explorer.
Tip:
You can also add a Verification approach by highlighting specific runs in the Evaluate step (Evaluation Tasks and Evaluation Data tabs) or Post-Processing step (Summary tab) and clicking Verify.
