Load your own design matrix.
The
User Defined Design is read by
HyperStudy and
used like any other design. You must specify the number of runs (rows) and the
number of columns in the specified matrix in the first row of the supplied file.
Spaces, tabs, or commas can delimit the individual elements of the matrix. Each
entry in a row is an integer to represent the assigned level for the corresponding
variable: 1 is the first level, 2 is the second, 3 is the third, and so on.
Table 1. Example: User Defined Design
9 |
3 |
1 |
1 |
1 |
1 |
2 |
2 |
1 |
3 |
3 |
2 |
1 |
3 |
2 |
2 |
2 |
2 |
3 |
1 |
3 |
1 |
2 |
3 |
2 |
3 |
3 |
3 |
1 |
Usability Characteristics
- Create your own design based on individual requirements.
- The User Defined matrix uses integers to represent the
corresponding level of the variable. This is in contrast to the run matrix
DOE, which contains exact values of the
variables.
- The number of levels specified in the file must be consistent with the
number of variable levels specified in the HyperStudy user
interface.
- Imported values are mapped to the independent variables.
- Any data in the inclusion matrix is combined with the run data for
post-processing. Any run matrix point which is already part of the inclusion
data will not be rerun.
Settings
In the Specifications step, Settings tab, change method
settings.
Parameter |
Default |
Range |
Description |
Perturb File |
File that has the dataset for your own design of
experiments. |
Use Inclusion
Matrix |
Off |
Off or On |
Concatenation without
duplication between the inclusion and the generated run matrix. |
