Select a numerical method to use when evaluating the Optimization.
In the Specifications step, Mode column, select a numerical method.
In the Settings and More tabs, change settings as needed.
Click Apply.
A run matrix is generated using the numerical method you
selected.
Review and edit the run
matrix in the Edit Data Summary dialog. For more information, see
Edit the Run Matrix.
