Altair IPC Functions
There are five Altair IPC functions for exchanging data between the Altair program and an external program.
View new features for HyperWorks Desktop 2020.1.
Import templates are files that contain instructions for reading plot data files.
Export templates are Templex programs that export curve data to files.
You can create external programs for processing plot data in the program using the C programming language. Altair IPC, or inter-process communication, allows you to exchange data between the Altair program and an external program.
The external programs called from within the program must be written in C and incorporate the Altair IPC functions.
Altair IPC status codes can be used for error handling within your C program.
An external function executable should be tested and debugged using two methods before you call it from within the Altair product.
You can run an external function at the command line to verify that the function works properly.
Reads header information from the Altair program.
Reads vector data from the Altair program.
Reads the list of vector data sent to the external program.
Parses options sent via the command line to the external program.
Sends vector data to the Altair program.
ON THIS PAGE
ON THIS PAGE
