Keywords and Descriptions
Keyword | Description | Defaults |
$DELIMITER | Specifies the delimiter (<SPACE> <TAB>, ; : . etc.)
between the data. Note: # and $ should not be
used.
<SPACE> |
$TITLE | Specifies the title for analysis. It is an optional keyword. | |
$SUBCASE | Specifies the subcase ID and label. | ID = 1 Label = “Subcase 1” |
$BINDING | Specifies result binding (NODE or ELEMENT). | ELEMENT |
$LAYER_INFO | Specifies layer information (like the number of layers and layer labels). | |
$ID_POOL | Specifies the ID pool name. The possible values depend on the
model file being read (typical values are:
“Shell”,”Solid”,”Beam”, etc.). Note: If ID_POOL is given; then
the ID pool name should match the model file ID pool
names.
"Nodes" (for nodal bind result types) OR Elements (for element bind result types) |
$SYS_ID | Specifies the output result system (like Ply (-3), Material (-2), Element (-1), Global (0), User defined). The material and ply system information should be available from the model file (currently supported for OptiStruct and Nastran only). Otherwise the results are displayed as N/A anytime coordinate transformation is performed, as HyperView does not have complete information. | 0 |
$COLUMN_INFO | Specifies the meaning of data column (like entity ID (ENTITY_ID), centriodal/corner data (GRID_ID)). | |
$RESULT_TYPE | Specifies the result types used in the data column. Multiple result types, the animation source, and complex type can also be specified here. Specify the label for the data type followed by the type (Scalar, Vector, Tensor, Real, Complex, etc.). The label provided for the data type appears in the result name which is displayed in the Contour/Vector/Tensor panel. | |
$FREQUENCY | Specifies the frequency value in modal results. Units can be specified after the frequency value by separating them with a space. | |
$MODE | Specifies the mode number. | |
$TIME | Specifies the time value in transient results. Units can be specified after the time value by separating them with a space. | |
$INCLUDE | Specifies the include file path. The include file should contain only the data. | |
ALTAIR ASCII FILE | Specifies that the file is an ALTAIRASCII file. | |
(v), (t), (2t), (s) | Specifies result type format (like vector, 3D tensor, 2D tensor, and scalar). | (s) |
Anim Source | With the result type, specifies the animation source. A node based vector result type should be the specified animation source. | |
(R/I) or (M/P) | Specifies the complex result type; either in the Real/Imaginary, or Magnitude/Phase format. |
