amfIMovie GetWidth
Gets the width, in pixels, of the video.
video_handle GetWidth
Returns the width, in pixels, of the video specified by video_handle.
Error
3 = HW_InvalidHandle
View new features for HyperWorks Desktop 2020.1.
Creates a new marker for the movie.
Calculates the tracking data, using the OpenCV tracking functionality, for the markers.
Remove the first marker from the tracking system.
Remove the second marker from the tracking system.
Gets the final time of the tracking system.
Gets the value of the flag denoting whether or not the connecting line of marker1 and marker2 is the X axis of the tracking system.
Gets the first marker ID of the tracking system.
Gets the list of the marker names available as the first point of the tracking system.
Gets the first marker name of the tracking system.
Gets the second marker ID of the tracking system.
Gets the list of the marker names available as the second point of the tracking system.
Gets the second marker name of the tracking system.
Gets the start time of the tracking system.
Gets the height, in pixels, of the video.
Gets a handle to the specified marker, to be used to access APIs available to markers.
Gets a handle to the specified marker, to be used to access the APIs available to markers.
Gets the Length of the master measure in the selected unit.
Gets Length of the master measure in screen pixels.
Gets the unit type used by the master measure.
Returns the number of markers currently stored in the video.
Gets the value by which the video resolution will be divided in order to speed up tracking.
Returns the list of length units of the master measure.
Sets the display status for the master measure to off.
Returns whether the master measure is defined.
Returns whether the tracking system is defined.
Sets the value of the flag denoting whether or not the connecting line of the marker1 and marker 2 is the X axis.
Sets the x, y values of the first points of the tracking system.
Sets the x, y values of the second points of the tracking system.
Sets the length of the master measure in the selected unit.
Sets the x, y values of the end points of the master measure.
Sets the unit type of the master measure.
Sets the value by which the video resolution will be divided in order to speed up tracking.
Sets the display status for the master measure to on.
ON THIS PAGE
ON THIS PAGE
