hgtrans config SetChannelSelected
Marks a data channel for translation.
hgtrans config SetChannelSelected subcase, datatype, request, component, state
HyperGraphTrans Tcl Set
This command marks a single channel in the source file for translation.
- subcase
- The name of the subcase from which to read.
- datatype
- The name of the datatype from which to read.
- request
- The name of the request from which to read.
- component
- The name of the component from which to read.
- state
- True or false; whether to read from this channel or skip it.
hgtrans control SetFile “columns.dat”
hgtrans control SetOutputFile “columns.abf”
hgtrans config SetChannelSelected “” “Unknown” “Res. ang acc (rad/s**2)” “column 2” true
hgtrans control StartTranslation
None.
Keywords
set channel selection
