plt3DIAxis SetIncrement
Sets the spacing between tics for the axis.
plt3DIAxis_handle SetIncrement increment
HyperWorks Tcl Modify
This method is only valid for axes using the increment method.
- increment
- The desired spacing between tics for the axis.
Returns success or an error code.
