pltIBuildPlotsCtrl SetLayoutOption
Sets the layout option.
pltIBuildPlotsCtrl_handle SetLayoutOption option
HyperWorks Tcl Modify
This command sets the layout option. This command differs from the SetLayout command in that it sets the layout option rather than the layout (which is the number of windows within the page).
Note: The command GeneratePlot must be called after to draw the plot with these changes.
option
A string representing a layout option. The layout option inputs include: request (One plot per request), current (use current plot), component (one plot per component) or none (one curve per plot).
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SetLayoutOption component;
build GenereatePlot;
Keywords
HyperWorks
Tcl
Build Plots
Modify
