pltIDatum GetPositionValue
Gets the value (position) of the datum.
pltIDatum_handle GetPositionValue
HyperWorks Tcl Query
If the datum is horizontal, the position value is a y-value. If the datum is vertical, the position value is an x-value.
Returns the position value of the datum.
Note: This command is the same as the GetValue command, which is now deprecated.
None.
