pltIDatum SetPosition
Sets the value (position) of the datum.
pltIDatum_handle SetPosition expr
HyperWorks Tcl Modify
expr
A string indicating the new value for the datum. If the datum is horizontal, this is a y-value. If the datum is vertical, this is an x-value.
Note: This command is the same as the SetValue command, which is now deprecated.
Returns success or an error code.
