Delete Output Responses
Remove output responses from the model.
Delete output responses in the following ways:
- Select an output response in the Design Explorer Browser then right-click and select Delete from the context menu or press Delete on the keyboard.
Click the satellite icon on any of the Responses tools
. In the Responses dialog, select the response to delete then click
