Load Command Files, Scripts, and Solver Templates
Playback commands, run scripts, or load a custom solver template to automate your workflow.
- From the menu bar, go to and select whether to load a command file (*.cmf), Tcl/Tk Script script (*.tcl, *.tbc), or solver template.
- In the dialog, select the file to open.
