Optimization Constraints
Optimization constraint entities define and store constraints on model responses for optimization problems.
Optimization constraints do not have a display state in the modeling window.
Nastran Cards
Card | Description |
DCONADD | Defines the design constraints for a subcase as a union of
DCONSTR entries. Note: Collects constraints
DCONSTR | Defines design constraints. Note: Constraint to define lower and upper
bounds.
DESGLB | Selects the design constraints to be applied at the global level in a design
optimization task. Note: Global constraint; belongs in the subcase
section.
DESSUB | Selects the design constraints to be used in a design optimization task for
the current subcase. Note: Constraint dependent on the load step; Belongs in the
subcase section.
OptiStruct Cards
DCONADD | Creates a combination of several
DCONSTR sets that can be referenced by a subcase. Note: Bulk Data Entry
DCONSTR | Defines design constraint upper and lower bounds where
response is defined by DRESP1, DRESP2, and
DRESP3 cards. Note: Bulk Data Entry
DESGLB | Used before the first subcase statement, to select a
constraint set that is not subcase dependent. Note: I/O Options and Subcase Information Entry
DESSUB | Used within a subcase definition, to select a
constraint set that is subcase dependent. Note: Subcase Information Entry
Radioss Cards
DCOMP | Defines manufacturing constraints for composite sizing optimization. |
DCONSTR | Defines constrains a design response by specifying its lower and upper bounds. |
