Shapes
Shape entities are collections of handle and/or node perturbations from the initial configuration of the FE mesh before morphing.
When you morph your model, the morph is stored internally as a collection of perturbations which you can then undo, redo, and/or save as a shape.
Shapes do not have an active or export state.
